FS Parts: Mortal Kombat Kick Harness Condenser PCB
ToplessZ
Donor 11 years: 2011, 2013-2022
Claremore, Oklahoma
This PCB can be used to help you install more than one Mortal Kombat PCB in a machine. It has the headers installed for each MK PCBs kick harness. In order to install and play more than one MK3 PCB you have to have diodes between the kick harness wires to keep from getting feedback. This pcb will allow you to plug your cabs original kick harness into the middle of it, then plug each kick harness cable into as well so that you dont have to hack up any wiring in your cab and its plug and play.
You will still need some sort of multi jamma harness, this pcb is just for the kick harnesses.
Most games used the same kick button wiring, so this PCB will also work with Killer Instinct
Only the PCB is being sold. You will still need to buy/ make your own kick harness cables.
This PCB is marked for MK1, MK2, MK3, UMK3, MK4.
I have this new version that has MORTAL KOMBAT printed on top , and I have the old version that has two more rows of headers instead so you can have up to 7 boards connected. Let me know if you want the 7 header version.
45.00 shipped US
Links to get the molex connectors
They are a 2.54mm (.100) molex housing 15 pin for MK2-MK4, and 12 pin for MK1.
Housing
http://www.jammaboards.com/store/15-pin-254mm100-molex-housing-mh254-15p.html
http://www.mouser.com/Search/Produc...00virtualkey57420000virtualkey855-M20-1061000
Pins
http://www.jammaboards.com/store/molex-254mm-100-female-crimp-pin-mp254-1.html
http://www.mouser.com/Search/Produc...900virtualkey53810000virtualkey538-50-29-1900
Mk kick harness condenser
Hello,
Just checking to see if you still have the condensers available. I am looking for the one that has mortal kombat printed on it.
thanks
blake
I just wanna say this is genius, like 3M genius, "we don't just make things, we make them better" lol
thanks
I added links to find the molex connectors needed, the pins match the connector so dont buy mouser connectors and jammaboards pins.
I found some premade cables on ebay that might work great as jumper cables for this project. if you search for "60cm wire cable 7p" .. http://www.ebay.com/itm/New-5-PCS-6...673?pt=LH_DefaultDomain_0&hash=item4abd5c40f9
5 two foot cables for 5 bucks is crazy cheap and better then making your own. I think they have 100cm versions too. I ordered some but havent got them yet to test, Ill let everyone know what I find out.
*edit- You only need a 7 pin version since there are only 6 wires with an empty space in the middle , even though the header is a 15 pin.
got the cables from ebay, they work great and they are cheap so I highly recommend them, seller ships fast too. better than paying 15.00 for each kick harness.
thanks
Just FYI,
one of the links on the first post is going to a 10 pin not a 12.
You only need a 7 pin actually but I don't think they had a 7 when I looked. The cables on eBay work the best and they are cheap
