CrOoKiT6
Just got a MK4 unit yesterday and everything is great, except I noticed that the monitor is not as dark as my other MK's. I messed with the contrast and brightness but still it looks dark gray whereas MK2 & 3 look black. Also There are horizontal lines running thru it that are barely noticeable unless the whole screen is black. When I went to adjust the contrast and stuff i noticed that two of the dials are missing, one is the height adjustment knob, the other says D & C, what does that means? If it is a darkness adjuster how can i remove a knob to use it on that slot? And if it is not a darkness adjuster, what is my problem? thanx--crookit6
