Jon Hughes
Hi, has anyone seen a MK pcb like this one? I bought it from Holland - I haven't seen one like this before. It is a dual layer board stamped "mouse system" and possibly originated in Japan from a circular label on the board.? It was advertised as 100% working - Sure it was! Board was dead when plugged in to the cabinet. Anyway, there is a strangely place capacitor between the boards, which had one leg broken off. You can just make out the cap in the first pic about 2/3rds the way up the left edge of the board. Managed to replaced the cap.
The board is sensitive to anything to say the least. I did manage to power the thing up. It initially dispalyed poor RAM (4 number) in banks U10 to U33. The board displays bad sprite graphics. If I leave the board on for 5 minutes and then restart it everything seems to work just fine.
It is running version 2.0 from the display. The graphics are identical but the soundtracks are slightly different. Some are more or less as the original but others have been re-composed to sound like the original soundtrack. All the voices and sounds are in the correct order, etc. It's not like any of the other bootlegs I have seen.
Any ideas, opinions?
