MitchO
On the Mortal Kombat 2 monitor wiring does anyone know which of the two power wires is hot and which is the return? One of the wires is violet and the other is violet with a yellow stripe.
Thanks,
Mitch
Thanks,
Mitch
Thanks,
Mitch
The only reason I asked is because the monitor manual said they had to be correct and I am not a monitor expert.
I was just looking at the service manual for the game and it lists violet as 0 and violet-yellow as 120. So presumably violet is return and violet-yellow is hot. Correct?
Mitch
Weird, so I guess I don't know how to read schematics, at least AC signals anyway.
Mitch
OK, now you are making me confused. I guess I'll just plug the cables into the Polo and hope it doesn't complain.
Mitch
OK, now you've got me really confused. I've seen those diagrams but I don't see how they apply. See the one I attached and tell me what I'm missing.
Also, I tested the monitor power line with one of those AC line testers and it said that violet/yellow was hot and violet was neutral. I don't know how accurate it is since it's designed for testing wall plug AC connections.
Mitch
