azrael_nite
Hello all,
Working on my first cab
Looking to replace the stock speakers with PC speakers in a Mortal Kombat 2 Cab. I removed all front screws and attempted to remove the grounding screw from the backside. (no luck removing that screw). Is there an easy way of removing the grill? What I want to ultimately do is replace the speaker board with a modified version or gain access to that board so that I can cut speaker holes.
I've attached a pic of the cab that has the grill outlined in YELLOW. I would like to remove the grille without ruining it and it would also be nice to be able to re-use the original speaker board. Does anyone know if that board is screwed in or nailed in? Is it feasible to do?
Any and all help would be welcome.
Thanks,
Thanks,
