Mortal kombat 2 cab
datn1zzle
Portnorris, New Jersey
I have a dedicated mortal kombat w and for some reason my coin and dollar acceptor do not work. Everything seems to be wired up, but I get no lighting and it does not accept the quarter or dollar. Any help? Thanks guys!
Ive never worked with the dollar acceptors before... but I have worked on MK2 doors... Are the coin switches wired properly? Have you manually tried using your finger to trigger the coin switch? Do you have coin mechs installed? Last but typical question: Any pics?
Okay I have It working now. I t was just me thinking it wasnt working. The lights are blown and it doesn't like the quarter eject button. Okay so when I actually put a quarter in it just goes in but does not go all the way down to register I entered a quarter. I have to hit eject and it comes down into the pocket so you can grab it again.
As far as the dollar acceptor goes it will pull the dollar in and jut throw it back out. It will like try to swallow the dollar and spit it back out. I checked the rollers and they both are pulling in the dollar. The LEDs that check the dollar are coming on as well. I have no clue.
And for a picture I am on m y iPad but I will snap a photo and forward it to my mac. I will upload one shortly.
okay so i got the dollar acceptor working, it was the black rubber piece inside of the acceptor that was causing the dollar to get jammed. pushed it down and it is not working perfect. just the coin mech is having issues.
first pic is of the whole mech, the second is me pointing to where the coin stays until i hit eject.
okay so it is for tokens.. damn thats nuts. is there any way to adjust this? i just want to look at my arcade as a piggy bank lol.
thanks brian, i looked at the article, it seems like there was some stuff filed down and altered to make it work for coins. looks like i need to replace the coin mechs for quarters. its not that big of a deal but would like to put quarters.
if it's MK2 you're running, there's a dipswitch setting that you have to enable in order for it to accept bills.
the coin lamps you can go #161 (dimmer) or #555 (brighter).
