r3m
Well I have a MK1 sound board that is a little screwy. Random Goro sounds, falling in the pit scream, sounds of sonya when I choose raiden, etc. I've had it for a while but just decided to go ahead and try to fix it. I replaced about 12 capacitors that tested bad and I was checking a row of resistors and I'm getting crazy readings. I'm not sure they are even resistors. They look exactly like resistors but the body is light green and not beige like a regular resistor. When I check the ohm on the 11 what I think are resistors I get 8 out of 11 of them that says pretty much 90k ohm and the other 3 I get no reading at all. The color bands don't make sense on them either. Brown, black, brown, gold, white. I have replaced white as possibly being silver and get nowhere near what I'm reading on the meter. On the sound PCB these are c35, c36, c37, c38, c39, c40, c41, c42, that get 90K ohm readings. The 3 that don't have a reading at all are c43, c44, & c45. If they are resistors why don't they have an R in front of the number like the rest of the resistors? Also should I at least get a reading on the 3 that shows nothing?
I'm sorry if it's confusing but it's confusing me so bad I don't even know how to explain it.
Thanks!
Thanks!
