More weirdness from my 15v2000. This time smoke...
Okay, after some valuable assistance from some great and knowledgeable KLOVers, there is another chapter to my 15v2000 saga:
It was looking great, and everything was going well. Then after a week or so, I started to get some different strange behavior:
At boot, the image grew to what I would describe as "Full bloom" within about 10 seconds of becoming visible (the middle third or so of the image fills the screen in both X and Y), and there is a bright dot in the center of the screen.
I got a whiff of "hot component" and shut the game down until I could look more closely. When that finally happened, I assumed it was the HV diode, so I replaced it. The behavior continued, but as the monitor was out of the cab, I was able to see a wisp of smoke emanating from R900 (the big resistor) on the HV board. The PCB was also a bit scorched where R900's legs are attached.
Some additional data: When I initially pulled the monitor apart to recap and clean it, I did not use any grease to re-pack the HV diode, nor did I use any when I installed the replacement. My understanding is that the dielectric grease is there to prevent corrosion, not to facilitate the connection (wrong?).
I also used some Goof-Off to clean the flyback connector and the surface of the tube around the anode. This is also how I cleaned the springs on the HV diode connectors.
Does anyone have any ideas about what might cause R900 to smoke?
