RetroHacker
It's really rare to actually have a bad yoke. I'd bet more on a wire broken off at the lug on the yoke.
-Ian
-Ian
i put a jumper wire on it and tested it. it jumped up to 55
would i be safe soldering a jumper in for now? the wire is pretty seperate from the others so it wont touch.
I've been watching this thread all day and must admit i'm a bit disappointed in you monitor guys. The problem never was in the damn chassis to begin with, look at the picture. If there was a deflection issue, the line would have been thinner and it would have run from top to bottom on the tube. This has blown yoke written all over it
Surprised that someone who has fixed as many monitor chassis as you have has never run into a chassis that looked like this from a combination of issues. Just about every "bad yoke" symptom can be replicated by a chassis issue.
I initially suspected the yoke also, especially since he said it worked fine on the bench, but decided to give advice based on most-common to least-common, and FR401 is more likely than a bad yoke...
Huh? How, electrically, is a cracked solder joint at the yoke plug and a yoke with an open winding different? The circuit is not complete, and the deflection transistors will be sitting there driving nothing in both cases. The symptoms will be identical.
The line may look thicker than you think it should - but the position of the yoke on the tube, the lack of convergence (since he removed the yoke), and the setting of the focus and screen controls will all affect exactly how the line looks.
-Ian
it wasnt until the yoke word came up that he "knew it all along" ;-D
ha ha jk
i just read that whoooole thread Mod, AMAZING. Its where i stole the idea! ha ha
Actually Dave i've got around 60 GO7's sitting here all waiting for my love
