Moon Patrol Monitor
thefader
South Dakota
I have a buddy that wants a moon patrol recapped, but its not here so I cant look at it. Does anyone know what monitor is inside it? Thanks
No way to know - you have to look. Not only did manufacturers usually use whatever was on hand at the time, but they also get swapped around a lot. But, with that said, I've seen several Moon Patrols with WG 4900's in them.
-Ian
Williams mainly used 4900's, 4600's, or G07's. Most of the ones I've seen have G07's
As previously stated, there is no way to know, however more likely than not it is a WG 4903. The 4903 had several modications from the 4901 which allowed for a wider picture. If you do a thread search you can find more detail information on the actual differences, they helped me when I was doing my Moon Patrol restoration.
Greg
