Was doing a little research to see if there was a unused 74LS04 hex inverter that I could use to turn Moon Patrols negative sync into positive and I ran across this jumper...
I'm assuming CPS is composite sync and HS is horizontal sync.
Looks like I can move the jumper from the left side of R3 to pin 6 of the 74LS00... which is right next to it on the PCB. Correct?
If so, it almost makes it as easy as the other Williams games... almost.
