Monster Bash phantom flip issue
ELutz
LOUISVILLE, Kentucky
I've got a Monster Bash where the right side phantom flip doesn't work (the left side works fine, BTW). The eddy sensor is adjusted properly, and lights up when the ball rolls over it. In switch test mode the eddy sensor registers properly when the ball rolls over it. I swapped right and left sensor boards.....nothing changed. I figured the sensor is working, so the issue must be with the CPU no being able to flip the flipper bat. In flipper test mode, the flipper works perfectly.....so I assume the CPU is capable of controlling the flipper. At this point, I'm outta ideas. Am I missing something?.....Any ideas?
Thanks!
Edward
It goes by an opto switch and then over the eddy sensor.
Is your opto switch working ?
LTG :)
