Monitor Worked Now it Doesn't
herkemeyer
Colorado
Hi all,
I had a Shinobi machine that I sold. It worked when the customer saw it in my garage but when he got it home there was no video. The tube neck glows when turned on but nothing shows up the screen. If I remember right it was a G07 monitor. Does anyone have any ideas?
Thanks,
Eric
Neck glow means you're missing the signal. Check the video input cable on both ends, especially where it plugs into the chassis.
Turn up the brightness knob on the flyback to see if you get a white screen - that will tell you for sure that the monitor should be working, you need to track down why the video feed isn't reaching the neckboard.
Thanks for all the suggestions. I checked the fuses and connections but still have no picture. Anyone have any ideas?
if you can hear the high voltage going to the tube, I'd be checking the video connections like was mentioned before....
Hi all,
Thanks,
Eric
Driveway warranty = As soon as it leaves my driveway it is no longer my problem. I am not responsible for transportation or setup at the new location.
Sounds like the monitor, whatever make and model didn't like the trip to the new location.
