Monitor with horizontal collapse
bigbadmiker
Washington
I'm thinking about buying a MK2 machine, but the seller said it has horizontal collapse. I think it's horizontal. The picture is shrunk, about 4 inches on the left and right sides. I've only done a cap kit before, nothing else on monitors.
Will a cap kit fix this issue or is this a bigger problem? The cap kit I did a couple years ago was the opposite issue; shrunk from the top and bottom and the cap kit fixed the issue. I don't know if I'd be so lucky with this one.
possibly would with a re-flow. it sounds like cold solder joints.
what chassis is in it do you know yet?
the pots could be broken or dirty as well.
Peace
Buffett
Well, I bought it. It ended up being vertical collapse. So I guess I'll start with a cap kit.
