monitor wave
paul400
Hixson, Tennessee
pickedup this Galaxian last night and it was playing blind.gotta it home and turn it on and the monitor came on to my delight. it has a bad wave to it but was playable. has a switcher wired in and the fuse holder was by-passed. would a cap kit clean this up and or should i look at the hacked job of the wiring. its a k4675
replacing 1 cap is most likely not going to solve your problem. do a cap kit and go over all the solder. especially for the 2 cards.
It *might*, if it really is a bad filter. But this is a 4600. If you go to all the trouble of taking it apart, you should really replace all the capacitors and reflow all the solder joints while you're in there.
-Ian
i always have a 4600 cap kit for these occasions, not sure if a have a filter cap. i know i have one for a go7 and sanyo, have to check the value for a 4600
