monitor swap?
pinnut
New York
a friend has a wg 4900 in a game. moving the game he somehow broke the neck . its a 19" vertical monitor. i have a 19" vertical monitor with a GO7 chassis. would my tube work in his game? cant see a tube # on the new tube, there is a big metal shield covering the tube on the back. his chassis frame has a sticker says crt type " 19vltp22/19vmcp22/19vmkp22
thanks
Why not just swap the entire monitor out (chassis and all)? If you're wanting to swap just the tube, you'll be in for more of a headache due to having to swap yokes too, most likely. The tube itself, yes, I believe is compatible, but you still have to use the correct yoke for the chassis you intend to use.
good point, but i was hoping to retain the working GO7. thanks
