Looks like Kortek KT1420A which requires an isolation transformer. Your sync select switches are set to odd settings. They both must be in the same direction: either both to negative sync or both to positive sync depending on the type of sync you're sending it.
This monitor looks like it never had a capkit. Do it now!
is it just me or is that neckboard not on there straight?
So the monitor smells better now?![]()
