monitor shake
monsterbaldy
Chandler, AZ
I have a joust and it works well, but when I hit the buttons on the cp, especially if I hit them hard, I get some image shake. It seems like the "shake" is the image going between maybe an 1" total shorter to normal.
When you leave it alone monitor looks great.
When you leave it on for a while no improvement.
Chassis seems pretty solidly mounted.
ideas?
What monitor is it? It sounds like you either have poor contact across a connector or cold solder joints. The cold solder joints would be my guess and they would be present somewhere along the vertical deflection line most likely.
