GCS2000
I'm talking about the black wire that connects to the video input connector between the blue and yellow wires. I see it goes up there, but can't see if it's connected. If not, then you'd get this problem. If it's not crimped down fully, you'd get this problem.
A couple other things to try:
a) Remove the yellow wire. The K7500 doesn't need the vertical sync if it's composite, and it can mess up the sync. If it doesn't help, put the yellow wire back.
b) Try moving the sync to the negative pins...
Removed the yellow wire and got no picture.
Not sure what you mean by choice (b) though
Also where is H-Hold is it that blue pot right by the black connector in the pic above?
The diagram in the game says h-hold is on the remote but its not
Greg
