GCS2000
This is on a Rush the Rock
What should I look for?
Greg
Greg
Let's see a pic of the video connector as it's connected..
Hmm which connector would that be the one going from the monitor to the main board?
Greg
A couple other things to try:
a) Remove the yellow wire. The K7500 doesn't need the vertical sync if it's composite, and it can mess up the sync. If it doesn't help, put the yellow wire back.
b) Try moving the sync to the negative pins...
if you're worried, just shut it off while fiddling with the connector....
