most games run standard res. the only real exceptions are probably the stuff Atari was mostly putting out in the 80s, then 3D-based games by like Sega or Midway in the 90s (both EGA/medium res), and then pretty much all the shit that's out now (VGA/high res)
most of the "modern" stuff of the last 15 years will also come with a resolution switch function, usually via dipswitch, because a lot of times these games were kits installed into existing games that had standard res monitors.
since you asked though, I will add ones that I'm familiar with to your list..
Wells-Gardner K7000 19" & 25": standard (typically) or medium (believe it or not) (isolation transformer required)
Wells-Gardner K8000 33" (and others, don't know exactly): standard or medium (dual isolation transformer required)
all monitors listed below here come with SMPS and do not require isolation transformers
Wells-Gardner U2000 25" & 27": standard
Wells-Gardner U5000 25" & 27" & 39" K7600: standard & medium (switchable via jumper)
Wells-Gardner K7400 25" & 27": standard
Wells-Gardner K7500 25" & 27": medium
Wells-Gardner U3000 19" & 27": high
Wells-Gardner D9200, D9400, D9800 27": standard, medium & high (tri-sync)
Hantarex Polo 19" 25" 27" & 33": standard
Hantarex Polo/2 19" (and others): SVGA
anyone finds any errors please let me know
