mgkastra
From the image below, you might be able to tell that the left side is more squished together than the right. The middle and right are fine, the left is squished. There is also a fold when a moving object passes to the right of the screen. A black line "scans" over the sprite. There is another about two thirds from the top that does the same thing.
I was reading around and it seems to be like "horizontal non-linearity." the fix said to increase the voltage with the "b+" adjustment.
It said this--
"Many sets no longer have any horizontal size adjustments and depend on accurate regulation of the voltage to the horizontal output stage to control horizontal size. There may be a B+ adjustment to perform first. On those that do, the adjustment may either be done by setting the B+ voltage, by a pot, or a width coil in series with the horizontal deflection coils."
--http://www.repairfaq.org/sam/tvfaq.htm#tvhpssla
I also cannot center the image. It is always more to the left. Horizontal transistor?
Also my horizontal width coil seems to do nothing. I have gone all the way both ways, with no noticeable affect.
Let me know what direction should I go in, if you wish. These problems are small, but wondering if anyone knows a fix.
It said this--
