Monitor Noise Question.
thepita007
Jacksonville, Florida
The monitor works now sharp screen and great color. However now it makes a noise and I cannot tell if its normal. The monitor is a NeoTec nt-2701
I recorded a video with audio so you can see if its abnormal noise.
The low dull noise is the fans in the arcade cabinent.
The high pitch noise is coming from the monitor.
This video is with the screen mainly dark with just a small menu open. The high pitch noise is barely audible from the back.
http://www.damngamer.com/soft.3gp
This video is with the monitor on a completly white screen the high pitch noise is audible from the front.
http://www.damngamer.com/loud.3gp
The noise is coming from the yellow transformer on the chassis. i swapped it with a different one but still get the noise.
Also is PH101 which is a thermistor supposed to get very hot to the touch?
