Monitor needs 10 minutes?
Zud
Madelia, Minnesota
I have a game that when I turn the game off I cannot turn it back on for like 10 minutes. If I turn it on sooner the monitor will not turn on, but the game will play blind. After about ten minutes I can turn the game on and everything comes up without a problem. Anyone else have a similar issue?
Sounds like it may need some attention. Probably a capkit and inspect for bad solder joints.
Thanks Ken. This would be a bummer since the monitor has a great picture with no burn-in. Game should be sold tonight so I wont worry about it. If he doesn't take it, then I will do an inspection as I will keep the monitor since it is so clean. :)
