I just came across a vs cab for cheap. Its missing the monitor, and I noticed that the holes in the brackets are really small. Does it take a special monitor frame to mount it? Any input would be nice.
Go to page 10 (page 8 in the actual manual) of this document. It shows how you're supposed to mount the monitor horizontally using the horizontal brackets that are in the cab. It takes only 4 screws to screw in the monitor to the brackets on the cab. You don't need a special monitor frame assuming you have an original Sanyo EZ-20 to put into the cab.
