YeehawMcKickass
I have a Midway cabinet with 25" monitor (U2000 chassis) currently mounted into it. During a move, the upper left mount tab that that connects to the chassis frame broke at the bend in the tab.
From what I can tell, when this part snapped, another part popped off. I'm honestly not even sure what the part is. It's a black box that connects to the anode and appears to ground to the uncovered cable that wraps around the outside of the tube (I've forgotten what the name of this is, but know it's important). Identification and function for the part would be neat to have, as I haven't seen this before.
That black box seems pretty trivial to deal with. It looks like the ground wire was just soldered on to the cabling and the box needs to be mounted somewhere in the cabinet. The real issue here is the busted mount tab. I'm not even sure if it's fixable within a decent amount of cash (that being around the cost of replacing with an LCD monitor, around $200). Any thoughts on fixing that tab?
