That's not good-
Dig around the schematics and see if that pin on the tube is actually used.
You may have some luck pulling the plastic protector away from the glass tube and attaching a wire or something to any bit of the pin remaining in the tube. You could route it around and connect it to the other side of the connector or something. You might even be able to rig it up where it connects through the connector again, but it would be fragile.
Make sure the pin is necessary first.
Oh- and you're adjusting the POTS (potentiometers), not the PODS.
And the metal finned pieces that help cool the transistors are heat SINKS, not SYNCHS.
K
K
