Monitor issues
Freezepop
calgary, alberta, Canada
im new to trying to get some issues working, the machine i have seems to work when i put in a board i get the sound, board works fine. but nothing comes on the screen. but it is powered on and works as you can see it turn on and go black. any ideas???
Is there any neckglow? I assume it is present since you can see the monitor power on and then go black.
Check the RGB sync and ground connector. It sounds like it may not be connected to the monitor.
either a classic shutdown symptom or missing screen voltage (from flyback)..
