Monitor issues plz help
Looks like monitor adjustment to me. What type of monitor is this? What this happening when you got this game or was it fine and then just went to this status? We need a little more info.
I woild star with turning your fly down, increasing your color gain and contrast. I've seen worse come together nicely with adjustment.
Electronic repair services
Servicing most monitor chassis
Sanwa, Wells, Sanyo, Sharp
[email protected]
for more info!
Mon
Bought monitor as working a while ago.. it's a 34" sharp image monitor.. I tried to adjust lightly.. I'll have to try even more adjusting.. think any components could cause this?
Have you ever had it working in that game? I ask because it is possible you just haven't hooked the wires up to the pins correctly...
Pins
I have not had this monitor working correctly in my possession... tried 2 different working pcbs and both look the same.. pretty something to do with chassis and not qiring.. even tried another harness I know is correct
What pcbs have you tried? Is the monitor the correct resolution? Have you verified the pinouts of the monitor wiring to make sure the sync pin is in the right place?
