Monitor ISO question
alexcc
Katy, Texas
This may be a dumb question but I'm not 100% sure of the answer...
I pulled an ISO of an off a cabinet with a 19 inch monitor.
Will the ISO from that monitor will work on a 27 inch monitor?
I'm pretty certain it does but want to make sure.
Yes, although some 27" monitors don't require isolation. It won't hurt to use it, though...
lots of iso's are ratted at 1amp max..
i doubt though that you would have a load pulling more than 1amp..
most monitors while running at high britness should hover around 1/2 an amp or just under.
best not to hook up other devices besides the monitor to the iso tap.
