Monitor identification needed
HedgeHog321
Hey everyone, I could some help identifying on old CRT monitor that was given to me. I'm told it was from a 1995 Midway Wrestle Mania cabinet. I was also given the control panel, and while not branded with Wrestle Mania, the graphics on the CPO do seem to match what I'm finding for Wrestle Mania.
From what I'm learning (and this is my first venture inside a CRT), is that I have a Zenith tube and a Wells Gardner chassis. Am I understanding that correctly?
Next, if you look at the far left side of the chassis picture, you'll see the plastic between the neck and the neck board is broken. It also appears that the pins coming out of the tube are a little bent. Is this something that can be fixed/repaired? Or am I just in possession of someone else's e-waste?
Back in 2002, I built a MAME machine for my kids running off an old PC and a VGA monitor. I am *very* curious if what I was given could be salvaged and used instead.
Thanks for any help!
Gotcha. So much to learn!
From what I'm reading, it looks like there are 3 options.
1) Be super careful and go without
2) Try to find a used one off a donor
3) 3D print your own.
Does anyone know of a thingiverse file for these? I found this one (https://www.thingiverse.com/thing:3637654) but I'm fairly certain that is for a different tube.
I choose option 1. Just leave the old one on there as well since it's still somewhat intact
