Monitor ID
Rrcade
Wisconsin
How do you know what model your monitor is? I usually only see a WG number but don't recall seeing a K7300, G07, etc. Is there usually a sticker in there somewhere?
often there are model stickers on the chassis or the frame (not the tube) that'll tell you what the actual model number is. WG usually has something like 19K4605 which will let you know that it's a 19" K4600 (of the 5th variant?) GO7 stickers seem to always be on the rear of the chassis and Sanyos like the 20EZ on the frame. the Korteks and Hantarexes i've seen have the model number printed on the chassis PCB and not on sticker.
sometimes those stickers are missing and you have to identify the chassis either by visual comparison to known chassis like on Bob's site or by other numbers on the chassis.
Look at the chassis you have, then compare it to the pictures you'll find on the following sites:
http://therealbobroberts.net/monitor.html
http://www.jomac.net.au/mon.htm
While the WG seems to indicate you can start by looking at the WG or Kxxxx labeled pics, sometimes you'll find WG labels on a Sharp Image or Nanao chassis, and you may also find someone swapped a WG frame onto a different monitor in order to get the new monitor to fit the cab easier...
You should see a white rectangular label like the one in this picture. Sometimes the label's glue dries out and the label falls off. Usually if it falls off, you can find it laying in the bottom of the cabinet somewhere.
