monitor I.D.
paul400
Hixson, Tennessee
does someone reconize this monitor, its a 25in. in a neogeo. pic 4 is somehow connected to the chassis. also a little fan is mounted on top of the flyback if that helps id the chassis.
Those are not good pictures with which to make an ID. I can make out possible references to Hantarex, Kortek, or even Wei-Ya models.
You'll need to pull the chassis to get better views, or at least remove the neckboard, get better lighting and focus, and get some full shots...
ok neckboard says kortek, anyone know what model this is?
wonderful obscure board nice. :)
likely cloned to the k7000 19"..
the fan may have not been on all runs of that board.. could have been a factory special or user mod.
I think its a factory fan. There is a tiny board mounted on the frame of the chassis that says 12vdc that connects to the fan.
