I did a bit more work on this today. It now includes the G1 voltage for every tube, and I think is a reasonable substitute for the B&K setup chart — just tap in the tube number, and you should have everything you need to test & rejuve it.
I think the only thing the setup chart has which this doesn't is the info on swapped guns for some tubes. I'll be adding that soon.
As always, it's at http://ieure.github.com/monitors/, the source is at http://github.com/ieure/monitors/, it works great on smartphones/iPads, and once you load it you don't need network connectivity.
