Monitor Helper 1.3.2 - mobile tube info & compatibility tester
Another update to this tube tool I wrote. To recap, modessitt wanted a phone app he could use when out looking for donor tubes. Then dezbaz & channelmaniac provided a CSV of the actual monitor data, and I put together this HTML/JavaScript tool for searching it.
The new version has the ability to show you only tubes compatibile with the one you need to replace. So what you do is search for the model number of the tube you need to replace, then tap it in the results list. Subsequent searches will only show monitors with the same pinout & heater voltage. You can tap the X to remove the filter.
As always, it's open source and available online; once the page is loaded, it will continue to work even if you have no internet service, as the entire thing is contained in one .html file. It works great for me in Chrome & Safari, and on my iPhone/iPad. Drop me a line if there's anything you'd like to see in this thing.
Next version is going to include neck pinouts. I got the data together, just have to work up the UI stuff.
