Monitor glass art peeling...how to save it?
AAirhart
Donor 2011-2012
Crafton, Pennsylvania
The Baby Pac glas finally started to crumble tonight... I have all of the pieces. Any options to save it?
Some Pinball guys triple thick the artwork to prevent the peeling in the future, I haev only done this once and it worked fine, looks like yours may be a good candiate for this...
Search of rec.games.pinball for triple thick and saran wrap.
Any fix like this is risky and not guaranteed, but what is guaranteed is that left like it is, your piece will continue to deteriorate.
I have a Black Hole backglass that had a couple of sizable pieces loose.. I did the triple thick, stuck the saran wrap to it, pressing the pieces into alignment and weighted down/flattened.. removed the saran wrap when dry, peeled right off. Mine worked well, but I could see it going either way. You really have to get some of the clear up under the loose paint for it to work. Good luck.
I used some krazy glue and it worked well. just make sure you dont glue the thing to your finger and then screw it up pulling your finger off.
