Monitor focus and test pattern issues
scottnagle
New Jersey
I have a Super Pac Man that I just can't see to get the monitor focused nice and crisp. It's playable but not at good as my other Pac Man.
Also when I use the Crafty Mech TPG, the vertical (top to bottom) grid lines are fatter than the horizontal. The both look white, but can't get it dialed in perfect.
Any ideas what might cause these issues?
Can you post a photo of the crosshatch pattern on your monitor?
The TPG uses 320x240 resolution for the crosshatch pattern, so the pixels are not square (as is the case for all standard res games to varying degree). So there will be a minor difference in thickness between vertical/horizontal lines in the crosshatch.
