djw90 Well-known member Donor 2011 VAPS Joined May 14, 2008 Messages 13,112 Reaction score 112 Location spokane, Washington Jan 6, 2010 #1 Does anyone make monitor extension plugs. It would be nice to be able to plug a monitor into a different machine without pulling the monitor?? Last edited: Jan 6, 2010
mudhens1 Active member VAPS Joined Oct 30, 2006 Messages 1,455 Reaction score 15 Location chillicothe, Ohio Jan 6, 2010 #2 bob roberts sells them...i have the power supply and the rgb/sync cable extenders...they work great
DP Louie Well-known member Donor 2011 VAPS Joined Nov 23, 2008 Messages 2,184 Reaction score 155 Location Visalia, California Jan 6, 2010 #3 Yep, Bob Roberts... http://www.therealbobroberts.net/videox.jpg
OP OP djw90 Well-known member Donor 2011 VAPS Joined May 14, 2008 Messages 13,112 Reaction score 112 Location spokane, Washington Jan 6, 2010 #4 Thank you guys This will be a great help!!!
CrazyKongFan Well-known member Joined Apr 16, 2008 Messages 3,809 Reaction score 411 Location Michigan Jan 6, 2010 #5 I made one for my Gaplus cab, which uses a 6 pin AMP plug. I've currently got it hooked up to a temp harness for my Crazy Kong board
nanoryan Well-known member VAPS Joined Jun 5, 2006 Messages 1,337 Reaction score 248 Location Washington Jan 6, 2010 #6 djw90 said: Does anyone make monitor extension plugs. It would be nice to be able to plug a monitor into a different machine without pulling the monitor?? Click to expand... I made one from cheap CAT5E stranded cable (got it at Vetco). http://forums.arcade-museum.com/showthread.php?t=113164
