Monitor discoloration
blackheart
Arizona
I believe that the monitor is a D9200. It is in a 2004 Golden Tee.
Rarely the monitor looks good. However it has began to tilted clockwise about 10 degrees. I know how to get into the monitor main menu but it can't be adjusted there.
More concerning is the discoloration that occurs. It gets a very red tint to everything. When hitting the trackball it will flash to the correct coloring for a few seconds, sometimes it will last for up to an hour. Then it will go back to the bad screen and stay that way for days. I have cleared the memory to reset it and have also used a manual degausser. Neither helped.
Yeah, if your picture has rotated, your yoke has moved. You'll also get color changes if the yoke has moved as well. Throw on a pair of rubber gloves, loosen the little set screw thingy and gently rotate it side to side to get the angle correct. Moving it in and out can help with the color. There are lots of tutorials out there on it...
If the colors go away after while you have a cap that wants to go bad. As a monitor warms up the heat can change the capacitance of a soon to fail cap.
