RonnyRage
Hey there....long time no habla.
So my monitor was working fine until last week when I turned it on to play my machine. The monitor had a yellow tint to it, similar to a problem that I had ecountered last year that was a result of a loose connection from the converter board to the jamma connection on the back of the monitor.
The way I had it was splices between the original monitor cable, and the one that comes with the arcade converter board. (In the picture you can see that the ground cable is still spliced, and the rgb cable isn't anymore.)
So my question is, how do I go about attaching the rgb and ground wire that come from the board directly to the connecter for the monitor?
