Monitor Chassis ID Help
phyllurus
Seattle, Washington
I went through Bob Roberts monitor ID page and wasn't able to find a match. This is in my Joust cab, and it doesn't look like a 4600, 4900, G07 or MTC900 that would have come in it originally. Any ideas?
Looks like the caps have been replaced already.
Most of the time numbers are on the side of heatsinks.
What type of problem you have?
Did you check for bad connections?
any heater glow?
I wouldn't replace the caps if they have been changed already.
I would trouble shoot the chassis.
by putting my meter on the regulator see if I have any voltage there.
right of chassis on heat sink.
sometimes the flyback numbers will let you know which chassis uses the fly.
Good Luck!
