GuidoTorpedo
I have the following non working chassis for sale:
-Wells 7400. Missing some caps and pots. Has neck board and remote board.
-Wells D9200. An issue on the neck board causes the monitor to lose green after a while. Neck board has different male connectors than the female connectors, but you should be able to fit it all together. Can't remember what the other issue was, I think vertical collapse. Comes with remote board and rgb/sync-VGA board that mounts to the frame.
Pentranic dual res: this was actually mated to a WG5515 tube in a 720 when I got it. It fired up for about 10 minutes, then got dark and picture went out.
Pm if interested
Mike
Pm if interested
Mike
