monitor burn
mindbinge
Virginia
are the new monitors better, worse, or the same for burn?
If you replace the existing monitor with a new one, what sort of life span can you expect before you start to see new burn if you mostly leave the game on?
it only takes a year or two of constand use to form burn.
"new" monitors tend to have krappier tubes, usually the tube goes bed before it gets a chance to burn in heh..
as far as fixing screen burn, the only option is a new tube or swapping a tube from a tv set.
i had a vision pro that was in my pac for over a year, and i never got burn with it left on. assuming you're not leaving the game on 24/7, i don't think you need to worry that much about burn.
