Monitor/Board Sync issue?
daskrabs
Philadelphia, Pennsylvania
Ok, so I'm just trying to test a Neo Geo 6-slot board. Looking for base functionality. I have a Pentranic CH-288 monitor and the Happ SNK PSU (here). I'm 90% sure I don't need an isolation transformer w/ this monitor, and I'm not using a noise filter. I don't have one. That's all I have hooked up.
I have the 9-pin power molex connected to the Neo harness. I have the 4-pin power switch molex lines crossed 1-3 and 2-4 so the PSU will turn on (I haven't wired the power switch in yet), and I have the 6-pin video cable from the monitor wired to the Neo harness as such: I have R to R, G to G, B to B, Ground to Ground, and Hsync to Sync. Supposedly my chassis supports composite sync over Hsync.
I get this:
I had this monitor hooked up to a PC via ArcadeVGA earlier tonight, and it was fine. I'm thinking either it's a sync issue on the board, or the fact that I have no noise filter is messing up the sync. Thoughts?
I found a thread relating to the topic, and traced the circuit from Pin P (sync) to 126 of LSPC-A0. All good. The 2 resistors measure out fine as well. I'm starting to run out of ideas? Can anyone suggest anything?
Here's a diagram of my setup:
Am I missing anything?
