So I'm done with my 4 player cab and everything turned out good but I tried to cheat and use a 30 inch HD CRT tv monitor instead of buying a flat screen arcade CRT. It has component inputs but I couldn't find a auto sensing VGA to component video decoder so I went with a gonbes that had svideo out on it. It looks so so but doesn't look nearly as nice as the 27 inch CRT in the cab next to it. My question, is there a auto sensing VGA to component video decoder out there and if so would it make much difference or do I need to go ahead and pony up the 500 plus shipping for a 29 inch makvision? Or does anyone know where to get a quality one that size cheaper? I'm using a xxxx in 1 board which has VGA and cga outputs if that makes a difference. Any advice is welcome. And in general where do you guys buy your arcade monitors from? The makvision one I found was on xgamings website. Thanks again for any help you can give.
