Molex supply
CAsh4kiDZ
Bloomfield twp, Michigan
Hey - New to fixing and replacing the wiring on a few of my cabinets and I cannot seem to find a place that sells molex connections online in an understandable way. Molex.com is super confusing. Any advise? Where does everyone purchase from?
Thanks- CZ
I have them on my site also, with pictures if you need to match it up visually.
I will be restocking all my molex in a month or two and adding a full line of .093.
Reply
Hey Riptor,
That does help a lot. My story is I have a multi configured kick harness for a mulitjamma mk project. It has that connector on it and I now realize, thanks to you, I need to use a pin header which makes a lot of sense.
Now wiring the buttons directly to the pins seems like the wrong way to do this. Is there some kind of pin header board I can purchase to help with this? I it 11 pins on a single row.
I will be purchasing the things I need from you once I know exactly what I need.
Thanks - CZ
Im not sure what your working with, pics would be the easiest way to get solid advice. I know midway used a double ended header pin on the kick harness. It would connect two female connectors together. I dont carry those exact headers but I think I have some .100 double ended headers around somewhere.
