Molex connector help on Super Pacman
scottnagle
New Jersey
I need to know what type of end connector I would use to attach the speaker wires to properly make a plug in connection on the main pcb. Someone soldered the speaker wires directly to the pcb board and I have no sound, see pics attached.
https://www.arcadepartsandrepair.co...56-molex-kk-series-connector-housing-no-ramp/
https://www.arcadepartsandrepair.co...lex-156-breakaway-24-circuit-header-vertical/
https://www.arcadepartsandrepair.co...rifurcon-pins-female-22-26-awg-loose-10-pack/
https://www.arcadepartsandrepair.com/store/connectors-sockets-pins/molex-156-housing-polarizing-key/
this is EVERYTHING you need to put that back together properly. header, connector housing, polarizing pin, and trifurcon pins 22-26awg (you can't use the 18-20awg pins because they won't crimp properly). i have all the tools in stock if you need any also, so just ask if you need any help and everything is in stock and orders ship same day.
This is my spm harness
Also looking for R1 from an Atari Space Riders pinball machine, do you have it?
