Modern day 100Volt replacement power
tom11011
Ohio
Hi Group,
Is there an "all in one" modern day power supply that can supply all the voltages needed for an arcade? ie- 100volt AC, 5vdc, and 12vdc ?
If not, is there a modern day equivalent for 100 volt AC instead of the old style exposed transformer?
b&k makes a 100/120v ac transformer but i just use a (much cheaper) nintendo iso and a separate switcher for DC voltages.
Isoation transformer. The ones used in Nintendo applications for the Sanyo monitors are 100v. As he said there are newer versions made, but nothing that will do AC and DC in the same form factor. Best to just stick with a "old style exposed" and use a switcher or rebuild the original power supply (not transformer) when possible.
