MLR8C4 resistor array for a Strikers 1945 PCB?
airthrow
Burien, Washington
I bought a broken Strikers 1945 board, and I repaired a bunch of broken traces on it, but then I found out it's missing a resistor array. There's a group of 4, and the 3 I have say "MLR8C4" and then either "IAM" or "1AM". I'm pretty sure the missing resistor array would be the same. Does anyone know where I can buy a replacement?
Thanks!
Just remove one of the existing good arrays and figure
out what it is.
It's going to be either bussed or isolated.
Isolated means there is a single resistor between
every 2 pins.
Bussed means the first pin (usually pin 1) is common and
the remaining pins are resistors that share the common lead.
There are other variations of arrays but I don't think you
will find it used on that board.
Once you know if it's bussed or isolated and the value of the
resistor you can either order a substitute or just do what I do
half the time and make your own array out of existing through
hole resistors.
JD
Sounds like from the part # it's a combo resistor/capacitor array.
