MK2 speaker grill
smitymike11
Twin Lake, Michigan
I cannot get the speaker grill off my Mortal Kombat 2. I removed all the screws bit there is one that does not come out it the middle. It seems loose in the back but the front is not. It looks like the front wraps around some wood. How do I get this off so I can clean it and paint it?
You need to get that screw out in the middle and then it just pulls off the wood piece it is wrapped around. The threads may be stripped at this point. Might have to just pull it out with pliers and bondo and redrill the remains.
The screw in the middle has a round head with a nut on the other end, there were ground wires on it.
That's right, just take the nut off, remove the ground wire and pull the bolt out. then you grill should come out.
